ABS Delete : Proportioning valve question! HELP!!
I am doing an ABS delete on my integra gsr 95.
What kind of proportioning valve am i suppose to use?
can i use one from a civic or accord? or does it have to be one off an integra with non ABS?
please help
please help
im in the same position. I just played it safe and got a 40/40 from the junkyard. are you going to be using your ABS brake booster/MC?
use a 4040 proportioning valve and 96 integra RS hard lines or bend your own.
the 4040 has 4 lines going out the left and 2 going out the right
there is another 4040 thats different that you have to use different hard lines or do them yourself
thanks a lot. is it hard to bend the lines my self?
if you order the prebent lines from the 94 rs there 100bucks shipped to your door already bent and mint, i have 4 myself sitting in a box right now. only thing i have to do is reflare the rear lines cuz i had to cut em, but if you can get em off they fit direct to the 4040. and use the integra prop
2001, 95, abs, accord, delete, honda, integra, nonabs, proportion, proportional, proportioning, rs, s2000, tool, valve
