Stalls while driving; tach fluctuates
Old May 12, 2011 | 08:34 AM
60grit's Avatar
Default Stalls while driving; tach fluctuates
So, my '95 Civic LX sedan started having issues a couple weeks ago. Driving down the freeway the engine would momentarily stall; tachometer would drop to 0 then things seemed to recover fine and would run fine for hours or days. My plugs and wires were due for replacement anyway, so figured that was a good place to start. Today it stalled climbing a hill near home and did not recover on its own. It would turn over but wouldn't start until I had turned the key completely off; it would then start with no hesitation. Also, occasionally when driving along at a consistent pace and RPM's between 2k and 3k, the tachometer will start fluctuating up 200-500 RPM though the engine speed doesn't sound like it's actually changing.
Tried to check for codes after getting back home and getting a jump wire, but the CEL didn't blink at all.
Thoughts? Crank Position Sensor?
Old May 12, 2011 | 09:36 AM
1998GsRIntegra's Avatar
Default Re: Stalls while driving; tach fluctuates
Igniter
Old May 12, 2011 | 11:10 AM
bambam's Avatar
Possibly something internal to the distributor. Other probable cause is a loose thermostat ground. This is the ecu ground.
Old May 12, 2011 | 11:39 AM
96dxB16's Avatar
This would be my guess. Or the ignitor.
Old May 12, 2011 | 12:30 PM
m_shake's Avatar
Why did you make 2 threads about the same thing within 15 minutes of each other?
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/talls-while-driving%3B-tach-fluctuates-2934590/
Old May 12, 2011 | 01:59 PM
60grit's Avatar
Sorry about the dupe posting, I didn't realize the first one had posted. It obviously wasn't ready for prime time yet.
Thanks for the suggestions, I will check those out.
Bishop94
Sep 22, 2016 02:43 AM
PossibleDX
Dec 12, 2013 11:38 AM
MadVtak
May 21, 2007 09:39 AM
4crx4me
12
Jun 23, 2003 06:49 PM
Turbo Lude SH
Aug 7, 2002 12:01 PM
