Super Missle Filler Rod
Old May 12, 2011 | 07:38 AM
Tex Blackwell's Avatar
Default Super Missle Filler Rod
Anyone heard of this stuff? Tried searching didn't come up with anything.
Old May 12, 2011 | 08:10 AM
McRussellPants's Avatar
Default Re: Super Missle Filler Rod
Super Missle is a marketing name for 312 from Harris and Weldco. People spaz out when they hear it because missles are magical.
Its for dissimilar metals, I've heard varying opinions about it, I used it at my old job and it seemed to work alright, I haven't bought any 312 for myself though. I've read that pipe welders used to root pass 310 and cap pass 312 when welding mild to stainless but have since moved on to using straight 309 filler.
Old May 12, 2011 | 03:38 PM
b00stcreep21's Avatar
I've got some, but only used it a handful of times. I have yet to come across a situation where I NEEDED to use it. It has a high oxide content, and leaves a very colorful weld, even with poor gas coverage. The guys that I first heard about it from say that they use it when they don't know the particulars of what they're welding together, and also use it for dissimilar metals like McRussellpants mentioned. They also use it to weld roll cages together I guess... I wouldn't feel comfortable using it for any kind of exhaust work personally, but it gets used for other random jobs around the shop sometimes
Old May 12, 2011 | 09:30 PM
javierb14's Avatar
not my bead, but I'm pretty sure that this vband flange was welded to the cast housing with "super missile"
It flows a little different when compared to 309. On the subject of 309, i used some on a cast DSM manifold a couple of months ago. It was a rush job, customer needed a last minute EGT bung repaired and i didn't have any "super missile" on hand. It worked great.
.john.
Welding / Fabrication
Mar 4, 2008 06:52 AM
dfoxengr
29
Dec 18, 2007 10:00 AM
will7
Jan 10, 2006 07:54 PM
slowata
Apr 21, 2005 02:55 PM
Scean
Mar 26, 2004 11:45 AM
