Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Civic 92-00 srr racing. Bearing Rod Assembly
Old Sep 29, 2002 | 10:05 PM
mantic6t9's Avatar
Default Civic 92-00 srr racing. Bearing Rod Assembly
What do you guys think about this product? Would it be worth it, they are $100.
CIVIC 92-00 SRR RACING. BEARING ROD ASSEMBLY
CAR : Honda Civic 1992-2000 All Models
Material : 10,000lb Fully Forged Aluminum
Bushing Material : Ball Bearing Bushings
It will Fit All the 1992-2000 Honda Civic 2 Door, 4 Door, and Hatchback's.
This item directly replaces the OEM Junk Bearing Rod. This item will eliminate all sloppiness during steering inputs. This will make the Steering wheel and Front Tires react PRECISE and not sloppy.
This item Makes Steering Enjoyable. It provides Crisp Steering, and eliminates the Junk feeling you have right now.For Road Racers and Drag Racers, This is a MUST HAVE to drive perfectly and react to situations.The OEM Bearing Rod is junk that makes Steering feel WAY TOO SLOPPY. These are a must for road and street raced Honda Civic's.IT Will completely change the way you take corners forever in the car
Old Sep 29, 2002 | 10:57 PM
Mojo-Jojo's Avatar
Default Re: Civic 92-00 srr racing. Bearing Rod Assembly (mantic6t9)
If I remember correctly, there was a warning on a site that sold those that said they are a race only part because a pothole or speedbump or something will totally **** **** up.
Old Sep 30, 2002 | 05:05 AM
Knestis's Avatar
I would LOVE to hear how many thousanths of an inch of stock rod end movement defines "WAY TOO SLOPPY"! They do LOOK like racing parts, though, so strut brace logic applies but I wouldn't want to buy a used Civic that had a set of these living on it for a couple of years - ignored, unprotected, full of salt and grit, and not lubricated.
Bling,
Kirk
PS - I particularly like the reference to "street raced Honda Civic's [sic]". There is a clue there...
Old Sep 30, 2002 | 06:33 AM
Doctor CorteZ's Avatar
waste of money.
Old Sep 30, 2002 | 12:13 PM
johng's Avatar
Default Re: Civic 92-00 srr racing. Bearing Rod Assembly (Doctor CorteZ)
I like the MOOG tie rods on Nash's car. They're way beefier that OE, and they have a grease nipple on top of the ball joint.
Old Sep 30, 2002 | 09:19 PM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default Re: Civic 92-00 srr racing. Bearing Rod Assembly (johng)
ehh, maybe not Moog's...
http://www.safetyalerts.com/rcls/nht...t98/98e031.htm
anyway, I've spoken to SRR tech on this piece. they recommended use on full race car only. apparently the piece can get damaged if you jack up the car fully. from what he was trying to describe (in chinese), i'm guessing the rod end is not big enough to give it lots of range of movement so the suspension starts to drop it reaches the limit of the range... and could get damaged.
and performance wise as others have said probably is minimal. you can not feel any slop if the steering tie rods ball joints are in good shape.
Fero
Honda Motorcycles
Apr 20, 2017 11:02 AM
918TastyGarage
Suspension & Brakes
Jan 12, 2013 02:06 PM
cj90si
Honda Motorcycles
Oct 3, 2011 04:22 PM
kneeslide
Honda Motorcycles
Mar 2, 2009 07:38 PM
EL-Driver
May 14, 2003 03:10 PM
