Trying to ID some camshafts
Old May 11, 2011 | 02:24 PM
C_Rock77's Avatar
Default Trying to ID some camshafts
They look like OEM cams. The intake doesn't look like an ITR/CTR cam, and I'm unsure what the numbers are for GSR/B16 cams. I took the time to check lift/duration using the Belben degree kit.
Intake:
Max lift .445"
Duration @ .050" lift = 245 degrees
Exhaust:
Max lift = .406"
Duration @ .050" lift = 235 degrees
Any help?
This is confusing the Hell out of me b/c the distributor end doesn't have the grooves like the articles show, but the profiles look to be more aggressive than GSR.
Old May 11, 2011 | 02:38 PM
kingofbattle909's Avatar
Default Re: Trying to ID some camshafts
https://honda-tech.com/forums/acura-integra-type-r-8/bump-stick-specs-2843720/
Old May 11, 2011 | 02:51 PM
C_Rock77's Avatar
Well....check you out. Thanks for the quick n dirty list.
That's what got me so confused. Lift/Duration numbers look like R cams, but the cams don't look like R cams.
petwhookie
Dec 25, 2009 06:24 PM
Cesare1987
Feb 5, 2006 12:46 PM
KustomCrx
11
Nov 17, 2004 10:10 AM
IgniteTeg
Jun 30, 2002 11:57 PM
