Is it the 91 civic 4 door ex master cylinder and booster that will work in the crx?
Old May 11, 2011 | 12:42 PM
SFlCrx's Avatar
Default Is it the 91 civic 4 door ex master cylinder and booster that will work in the crx?
Can't remember exactly Which model. But pretty sure it's a 4 door.. Thanks
Old May 11, 2011 | 12:46 PM
eaperez209's Avatar
Default Re: Is it the 91 civic 4 door ex master cylinder and booster that will work in the cr
just got with the 90-93 integra w/o abs its a lot easier to find and also the 40/40 prop valve
Old May 11, 2011 | 12:49 PM
SFlCrx's Avatar
My master cylinder took a **** on me 2 years ago and I replaced it with the bigger one from a 4 door civic. Direct drop in but now the booster is starting to go so I wanna match it the correct booster.
Old May 11, 2011 | 12:52 PM
SFlCrx's Avatar
I replaced the stock 7/8 one with a 15/16
Old May 11, 2011 | 01:01 PM
eaperez209's Avatar
its a 91 ex with rear disc brakes
Old May 11, 2011 | 01:12 PM
spcrxracer's Avatar
It doesn't have rear discs.
The 1991 Civic EX has 10.2" front discs and rear drums.
It also has a 15/16" master cylinder and a 3540 proportioning valve.
Old May 11, 2011 | 06:02 PM
Tyson's Avatar
Thank you for answering correctly!
Yeah 90-91 EX 4dr. And no rear discs, only the 90-91 crx si got rear discs.
Old May 11, 2011 | 08:11 PM
SFlCrx's Avatar
Thanks guys
Old May 12, 2011 | 03:20 AM
singlecamsaint's Avatar
i thought the y49 crx's got disc brakes also?
skill178
16
Oct 9, 2011 04:38 PM
EF9ZC
23
Feb 11, 2006 01:22 AM
DENCIO
Jan 1, 2004 02:42 PM
Bnjmn
10
Dec 8, 2002 03:08 PM
