86 d16a1 head on a 89 jdm zc dohc
Old May 10, 2011 | 02:49 PM
trav_89_crx_b7's Avatar
Default 86 d16a1 head on a 89 jdm zc dohc
i bought a jdm dohc, the head is no good. i need to know what would be the best head to use. ive found a 86 integra in the scrap yard. thinking about using as parts motor. i also need to know if i can use the bottom end too...
Old May 10, 2011 | 03:01 PM
jlicrx's Avatar
Default Re: 86 d16a1 head on a 89 jdm zc dohc
86 D16A1 head won't work on the 88 and up DOHC ZC - it will bolt on but the mounting for the distributor and cylinder sensor are different - also, the bolt holes for the inner timing belt cover are not the same - all of the valve train would work
Old May 10, 2011 | 03:54 PM
my zc head is shot a lifter forced a valve into #3 piston and twisted a rod. no free float but really twisted. block is still good. i need to know what would be the best way to go?
Old May 10, 2011 | 04:06 PM
bump
Old May 11, 2011 | 06:57 AM
jlicrx's Avatar
get another ZC head - here is one that just showed up this morning:
http://www.thezcr.com/forums/showthread.php?t=25213
Old May 11, 2011 | 11:32 AM
if i want a little more horse power, what would be the best stock internals to run in the dohc. i would like to build a desent motor for my rex and i know that the zc is a good choice if you would be nice to help that would be great.
i appriate all the help i can get...hell this is my first honda, and first dohc zc...
Old May 12, 2011 | 10:37 AM
bump
chris riz
12
Sep 22, 2011 12:34 PM
90si-rex
Sep 13, 2009 09:29 PM
tyler100
Oct 22, 2008 01:59 PM
tyler100
Aug 13, 2008 06:25 PM
tharzarekta
Sep 2, 2003 12:23 AM
