dot3 vs dot4?
Old May 10, 2011 | 02:21 PM
crxguy406's Avatar
Default dot3 vs dot4?
So my rex manual calls for dot 3 brake fluid... the stainless steel replacement lines I ordered specifically for 88 to 91 CRX says to use dot 4. Being a complete noob at mechanical stuff, does anyone have a suggestion on which to use? Is there even really a difference?
Old May 10, 2011 | 02:37 PM
ef_cowboy's Avatar
Default Re: dot3 vs dot4?
**** ya there is..if it was me id flush the master cylinder before installing the lines BECAUSE THE TWO DNT MIX RIGHT,but if ur not racing on the track leave it
Old May 10, 2011 | 04:25 PM
crxguy406's Avatar
So basically, as long as I flush out the system... dot4 will work just fine in my rex?
Old May 10, 2011 | 04:42 PM
echoside's Avatar
Dot 3 and dot 4 are interchangeable/mixable in cars requiring dot 3 fluid, but if the new lines say to use dot 4, I'd use dot 4.
Old May 10, 2011 | 05:35 PM
crxguy406's Avatar
Sounds good, thanks for the help.
Old May 11, 2011 | 03:47 AM
CWBETB's Avatar
Exactly!
Actually my MC says on top use DOT3 or DOT4, DOT4 is better but a little more $$
Old May 11, 2011 | 07:34 AM
Tyson's Avatar
Just don't use dot 5, unless its 5.1 which is compatible.
Zebra
Honda Civic (2006 - 2015)
May 11, 2018 07:09 PM
deerman2701
Oct 13, 2014 03:29 PM
Tennobanzai
Suspension & Brakes
10
Jan 7, 2013 02:01 PM
rybred
Jun 30, 2003 06:24 PM
itrhybrid
Jul 6, 2001 11:08 AM
