lsvtec
Old May 10, 2011 | 12:23 AM
manoloek9's Avatar
Default lsvtec
wat up honda tech people,
ok my question is? how would it work out ?
my 95 gsr head with jdm itr cams, double sided springs, oem gsr valves, 320 injectors, blox manifold , blox 70mm throttle body , itr p73 pistons on my 94 b18b block??
Old May 10, 2011 | 08:33 AM
crazydominicanman's Avatar
Default Re: lsvtec
Overkill with the injectors. tb too big imo as well.
Old May 10, 2011 | 01:14 PM
m_shake's Avatar
Default Re: lsvtec
Injectors are not overkill(well if you run it untuned then it'll be overkill...but who would drive a untuned car??)
SEARCH, there are a ton of threads on lsvtec's and b20vtec's
Old May 10, 2011 | 07:50 PM
manoloek9's Avatar
Default Re: lsvtec
of cours ima tune it but when i tune it it should be a strong lil built right??
i also have a 62mm tb that should work fine too?
Old May 10, 2011 | 08:18 PM
TheShodan's Avatar
Moderator
Default Re: lsvtec
Your BIBLE for this build
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
Old May 14, 2011 | 04:04 PM
manoloek9's Avatar
Default Re: lsvtec
koo thanx man!
OMG THE GOGGLES
25
Feb 26, 2011 08:59 PM
s032105k
Feb 7, 2011 10:02 PM
gsrob
Oct 1, 2007 07:42 AM
slow91crx
Jun 3, 2006 11:09 AM
batmang yO!
Feb 5, 2006 08:29 PM
