96-00 Civic short shifter trade for retainer
Old May 9, 2011 | 10:43 PM
cheggie's Avatar
Default 96-00 Civic short shifter trade for retainer
This is a good used 96-2000 Civic short shifter. I don't know the brand, it came from a swap parts kit. It worked well, I actually wanted the old clunky standard shifter in my DD. Also, I should note that since the lever arm is longer - under the car - it bumped against the heat shield on my OE exhaust and rattled. This was on a 5 spd swap car, I used a small spacer in the isolator that spaced the pipe away, and it worked fine that way. An OE stick car probably won't have this issue. Such are the perils of modification.
I need a retainer wire and screw for a driver's side 96 Civic headlamp bulb - the one that holds the bulb in place. I was hoping someone would have one out of a broken oe housing. Here's the deal - you pm me, with the part I need, and I'll trade you the shifter. Simple as that.
cheggie
Apr 30, 2011 07:30 AM
4gen5thtime
May 12, 2009 10:12 AM
Ray
Jun 14, 2003 06:47 PM
quik2kSi
Apr 14, 2002 03:07 PM
