Dpfi to mpfi question
Old May 9, 2011 | 07:12 PM
drift2004's Avatar
Default Dpfi to mpfi question
I've seen all the write ups and understand it all... But... I have a problem.
My brothers car is a civic ef standard model when he got the car they had convertered the interior harness to an si harness ... And he ran the car fine like that with a dpfi motor engine wiring.
So we just swap a d15b vtec motor but had no engine harness so I decided to use the dpfi engine harness and convert it... From my understanding si harness are different than dx but now I have no spark, no fuel, it's not cranking and when I try to start the car I have the brake light on .. So all plugs that go to ecu (A ,B and C) ( A1,A3,A5,A7,A15 are wired direct to the injectors and resitor box ) plug B and C I put them back to normal locations... Any ideas on what my problem might be? I'm thinking it could be the dpfi engine harness... But if I can make it work why not. And where would I wire the 2 cable for the distribution that go to c1 and c2 when doing the conversion?
Old May 9, 2011 | 07:25 PM
singlecamsaint's Avatar
Default Re: Dpfi to mpfi question
what you need to do is get a regular dpfi harness and do it c1 goes to blu/yel on the dizzy c2 goe s to blu/grn on the dizzy and if theyre backwards just switch em ill have to go look on mine...you need to move the existing wires at those the places to b10 and b12 then run wires from pins c1 and c2 to the dizzy.
Old May 9, 2011 | 07:38 PM
drift2004's Avatar
Dpfi interior harness? that might be the easiest way I think
Old May 12, 2011 | 05:43 PM
91efbluehatch's Avatar
^hahahahaha
Old May 12, 2011 | 06:30 PM
turbohatchBnuts's Avatar
you have to convert your dpfi harness to a mpfi harness very simple.
check this link out maybe this can help you. Double check the wiring over and over.
http://www.mnhondas.com/showthread.php?t=4883
wiring can be a pain but you cant give up. I know from lots of experience.
Old May 12, 2011 | 06:40 PM
just buy the kit on ey that comes with your ext. 02 wires, knock, etc.
thats what i bought, and im 18 with no elec. exp. and i put it in my hatch
ZAKU
Nov 18, 2008 04:15 PM
arsonest42
Feb 6, 2007 11:15 AM
yz125rider21
Feb 5, 2007 12:13 PM
DOHCintegra91
Sep 24, 2006 08:29 AM
elmalouno
Apr 26, 2004 02:35 PM
