Auto ecu on manual ls swap
Old May 9, 2011 | 04:56 PM
nolanator6's Avatar
Default Auto ecu on manual ls swap
i got a 95 ls swap in my eg hatch, im having a hard time finding an OBD1 ecu locally for a manual tranny. there are lots of auto swaps around so is it possible i can use the auto ecu with it? what would be the disadvantages?
thanks
Old May 9, 2011 | 06:04 PM
fonkernuckle's Avatar
Default Re: Auto ecu on manual ls swap
only disadvantage is that you will have a check engine light on, other than that none other. When inspection time comes you can always remove the cel light bulb from the cluster and if the cel light bothers you a piece of black tape over it will do it.
Old May 10, 2011 | 10:14 AM
94EG8's Avatar
Seagull Management
If you use a P75 you should be able to convert the ECU itself as shown below:
If you use an automatic PR4 you'll throw an EGR code no matter what you do (short of using a '92 - '93 automatic LS IM and wiring up the EGR valve)
brad22486
Jan 25, 2012 09:46 AM
h22honda89
10
Aug 19, 2007 02:40 PM
stefanne3
Aug 3, 2006 06:25 PM
projectTeG
Jan 14, 2006 01:19 PM
projectTeG
Dec 20, 2005 04:23 PM
