ef problems starting?
Old May 9, 2011 | 03:17 PM
andyvaj's Avatar
Default ef problems starting?
here's the deal... the car was running a week ago. one day i got and start up the car and nothing happens? good battery, starter good, alternator good! when i got to turn the ignition, nothing happens??? i am stomped? could it be on of the relays? check all fuse and they are good? anyone had problems like this before? where do i start? any info would be great! thanks
Old May 9, 2011 | 05:01 PM
ef_cowboy's Avatar
Default Re: ef problems starting?
if you turn your key and nothing happens and u say u have a good battery check the main relay(under the driver dash,around where you pop the hood).............if your starter is turning and u got spark and all that make sure you didnt brek a timing belt
Old May 10, 2011 | 03:34 PM
andyvaj's Avatar
yeah, nothing happens when i try to turn the key... no lights, not crank... just all quite.... i'll check the main relay. what else could it be?
Old May 10, 2011 | 07:52 PM
99SiStyle's Avatar
I just replaced my main relay, hope it solves my problem starting in hot weather. Was easy to replace, but putting the screw back in for the bracket was a pain! Seems like it starts a lot easier now, but may just be me.
Old May 11, 2011 | 04:44 AM
D16SiHatch's Avatar
if it were the main relay it would still crank. your problem sounds like either the ignition switch is bad, or even the clutch interlock switch. could even be the starter solenoid. see if you're getting voltage at the starter signal wire while cranking and go from there.
Old May 11, 2011 | 06:08 AM
crazyboy's Avatar
sounds like yor clutch switch to me, locate the switch and jump the 2 wires. if it starts then its the switch
Old May 11, 2011 | 06:36 AM
TJChad's Avatar
If you're not getting lights or anything do not start at your starter control circuit (clutch switch). Make sure you are getting power to your ignition switch. If so, you will need a new ignition switch most likely. Kind of difficult for people to diagnose a electrical problem over the net for you. Either get a wiring diagram and a DMM or take it to someone who has and knows how to use them.
Old May 11, 2011 | 01:22 PM
andyvaj's Avatar
the car does not crank or anything... lights don't work or anything... how do you jump the clutch switch?
Old May 11, 2011 | 01:58 PM
D16SiHatch's Avatar
locate the switch and then temporarily connect the two wires to eachother so it will thik the pedal is depressed. since you said that you have no lights or anything when the keys in the run position this leads me to believe that switch is not your problem. it's most likely the ignition switch.
Old May 11, 2011 | 08:33 PM
zach53's Avatar
ok no pwr at all.......if the alternator tests good the alt plug could be bad....also check all your grounds......if it was the main relay u should still have pwr and the car would crank.....i agree it could also b the clutch switch.......good luck bro
Old May 12, 2011 | 04:31 PM
andyvaj's Avatar
thanks guys... still trying to find out wat is wront... starter good, alternator good... will check clutch switch this weekend. thanks
Old May 12, 2011 | 05:53 PM
D16SiHatch's Avatar
no point in checking the clutch switch if you have no power whatsoever. The problem is with the ign switch, or you have a major ground or power issue. loose battery connection, loose ground, etc.
Old May 15, 2012 | 10:37 PM
jujin_9's Avatar
Why does everyone keep saying the main relay, the main relay is for the fuel pump, when a man relay goes out,the car would still crank but it wont turn on. It seems to me that its the clutch switch, just get a new one. i had that problem and i fixed it.
ethos909
17
Aug 24, 2013 11:09 AM
FlewByU352
Sep 22, 2011 12:15 PM
BigChina
13
Sep 5, 2008 08:58 AM
Parada
Jan 29, 2008 09:47 AM
Junkyard2000
Jul 4, 2005 10:55 PM
