valve cover bolt/stud
Old May 9, 2011 | 01:58 PM
khailon's Avatar
Default valve cover bolt/stud
i have an ls and the middle bolt on the valve cover snapped from previous owner over tightening
http://www.acuraoemparts.com/delray/...All&vinsrch=no
im not sure which bolt/stud to get
#18 or 19
its the bolt/stud located right in the middle of the valve cover on my ls
i think it also holds the bracket for the spark plug wire
thanks for the inputs
Old May 9, 2011 | 02:53 PM
unc25's Avatar
Default Re: valve cover bolt/stud
i would assume its #19
shows it to be in the middle. You'll have to remove the valve cover, and screw the bottom end into the head
Old May 9, 2011 | 05:17 PM
khailon's Avatar
anyone else want to make sure before i order
Old May 9, 2011 | 07:49 PM
Scooooter7's Avatar
That's easy, it's #19 cuz it is the longer one. And follow the line up to the center of the valve cover.
Old May 10, 2011 | 11:47 AM
khailon's Avatar
thanks!
Old May 10, 2011 | 02:26 PM
rollinkhutis's Avatar
If you havn't ordered it yet PM me... I have several valve cover studs laying around from LS and B20 heads.. You pay postage and I'll get one out to you.
Old May 10, 2011 | 03:06 PM
Scooooter7's Avatar
Good call Rollin!
I had to order four bolts from my local Thomas Acura and they charged me $5.50 per bolt. That is CRAZY! I checked the Delray site and their price was only $2.30 per, can you say rip off?
Old May 10, 2011 | 03:51 PM
khailon's Avatar
019 90012-P5A-000 BOLT A, HEAD COVER
i need that bolt
how much would that be send me a pm if you can
thanks
RoadRaceMike
17
Apr 10, 2011 08:13 PM
tegsallgood
Dec 7, 2004 03:18 PM
genetsang
Mar 25, 2004 02:40 PM
R.S.
May 21, 2003 05:56 PM
bartek_b
Apr 15, 2003 11:21 AM
