rsx engine shut off help!
Old May 9, 2011 | 12:59 PM
bradabu's Avatar
Default rsx engine shut off help!
i have a 2002 rsx. i blew my motor so i put a jam k20 in it and got the jam ecru. then that motor the head went bad...so i just put another ep3 motor in. k20a3 out of a 06 civic. with the same jam ecru. the problem is that when i drive the car, after like 5 min the motor just shuts off. i start it and overtime it shuts off like 3 seconds after. like i can be revving it and it will still shut off. like i kill the ignition while driving. but if i unplug the ecru and plug it back in i get to go for like another 5 min...anyone know why?????
thanks
Old May 10, 2011 | 08:40 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: rsx engine shut off help!
what is JAM? You mean JDM? And so did you run a k20a?
Why would you run a JDM engine on an EP3? The engines are completely different and not tuned anywhere close to the same?
Old May 10, 2011 | 08:57 AM
Bright13's Avatar
An 06 civic wouldn't have a k20a3
Old May 11, 2011 | 12:02 AM
bradabu's Avatar
yes jdm! and the motor that recently went in is a k20a3
Old May 14, 2011 | 06:00 AM
Jackal6042's Avatar
What codes is the ECU throwing? Its likely a compatability issue with the ECU/motor combo you described.
CIVIC9922
Mar 11, 2013 07:44 AM
Pav1986
Jan 24, 2012 06:53 AM
pias
19
Apr 10, 2009 09:34 PM
breakstylez
123
Apr 26, 2008 10:34 AM
