front wheel bearing
Old May 9, 2011 | 09:37 AM
ElCivic89's Avatar
Default front wheel bearing
I need a write up link to a diy front wheel bearing replacement! 1989 hatch si..
Old May 9, 2011 | 10:12 AM
dephtone's Avatar
Default Re: front wheel bearing
Your best bet is spend the 15 bucks on a Haynes' manual for your car. It is invaluable to have for doing anything on your car.
Old May 9, 2011 | 10:29 AM
zrickety's Avatar
you should use a hydraulic press. if you don't have one, you can hammer everything but sometimes the new bearing will get damaged. also, if you waited too long to fix it, your hub may be chewed up and you'll need another one. GL
Old May 9, 2011 | 12:05 PM
BiG ChOr!Zo's Avatar
https://honda-tech.com/forums/showth...=wheel+bearing
z6hatchboy
Feb 6, 2009 06:31 PM
petergriffen
Aug 11, 2006 08:44 PM
Jeff_B
Jul 9, 2004 11:28 AM
GeeSeeR
Aug 8, 2001 03:32 PM
