main relay fix
so if anyone is about to buy an $80+ main relay.. dnt... if you have a bad main relay you can fix it.. just unplug it and take it out, pull the casing off from it and on the board you will see all of the soldered parts. If you look closly you can see that it looks like some of the soldered points are "cracked" all u need to do is resolder them and it will work like new! hope this helps anyone!
whiteformula98
Aug 3, 2008 08:53 PM
