Info on tires and accords
What can be the widest tire i can use on a 15's, i need that cuz my car needs more handling from the tire, is not ABS equiped and the brakes are good enough to lock the tires, so i need to know the widest tire i can fit in the without changin the overall diameter of the tire, thanks guys
o by the way the car is a accord LX 95
Why not just get a stickier tire?
Its a 5.5 inch wide rim.
195 is recommended.
205 is possible.
215 is not suggested.
225 I've heard has been done once (will rub trailing arm without a spacer)(DONT DO THIS).
195 is recommended.
205 is possible.
so the widest i could posibly can is 215? i want experience from someone that did this and worked for him
thanks for your post wont be beat
so what would be the size for a 15 rim?
what would be your tire recomendation and what should be a good size of width of the rim? 6? or 5?
