NY 92 Si 5Spd, Apexi WS2, ACT clutch, H23 Motor etc...
Selling my 92 Prelude Si 5spd. The car was hit from behind the driverside quarter panel/tail light. Car was hit while doing less around 25mph making a left turn. Car was hit on quarter panel, door and fender (like a pit move). The bad are cosmetics. Needs a tail light, and driverside headlight. No frame damage at all. Hit on door did not damage enough to break anything in the door. Window goes up and down no problem and mirror was untouched. The good are that the car is 100% able to drive. I drove it from South NJ to NY after the accident with no issues and car starts up everytime. I did the timing belt, waterpump, cam seals, crank seals, acc belts no more than 4500 miles ago. Car has 146k EL cluster reads 158k. Struts were done no more than 500 miles with OEM ago. Car has an Apexi WS2 exhaust, ACT clutch & flywheel,Brake pads rotors done,new distributor, Blue EL speedo and temp gauges, 94-96 ebrake conversion done 100% the right way. Looking for $1k obo. The motor and clutch are worth more alone. If youre good at autobody its a great buy, If you need a motor with extra goodies, or even better if you're doing an auto to manual swap. Thanks for looking.
-Lou
914-497-1788
dark_rican@msn.com
Day of Accident
-Lou
914-497-1788
dark_rican@msn.com
Day of Accident
dark_rican
May 11, 2011 06:40 AM
92accord
Aug 10, 2004 11:31 AM
