Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Civic Manual Transmission ?
Old May 8, 2011 | 04:46 PM
SpoonREVS's Avatar
Default 2001 Civic Manual Transmission ?
Car: 2001 Honda civic LX coupe
Trans: 5 Speed manual
Problem: The car does not move at all !. You put the car in first gear and let go of the clutch and it doesnt move or shuts off!. All gears go into place with out any trouble even reverse.
Check:
Axles all seem fine no grease leak or broke axles and there all the way in. Check to see if shift linkage move with out problems and it seem all gears go in.
Can the clutch be this bad it doesnt work any more?
oh yeah and when I lifted the car and turn the wheels by hand they spun fine with out any problems. and theres no noise at all.
Old May 8, 2011 | 07:00 PM
lazlong's Avatar
Default Re: 2001 Civic Manual Transmission ?
Sounds like the pressure plate in the clutch.
Old May 8, 2011 | 08:29 PM
It Wasn't Me's Avatar
Sounds like a clutch problem. I doubt it's an internal transmission issue. You'll need to inspect the clutch components for damage.
Does the pedal still have good pressure?
Did you just get this car, or does it belong to someone else?
How long had the clutch been slipping before it finally stopped working all together?
Old May 9, 2011 | 03:06 AM
SpoonREVS's Avatar
The clutch pressure is normal
I just bought the car over the weekend with that problem.
it was a older guy that really couldnt give me good information he had no idea what happen and just one day it wouldnt move any more and took it to a mechanic and they told him it was a bad clutch.
will see im droping the tansmission today I would up date you guys today.
Dragon75
Jul 24, 2017 12:43 PM
Ajsbored
Mar 12, 2014 08:37 AM
civichb20
Jun 13, 2010 10:05 PM
Itu
May 18, 2006 11:06 AM
camera obscura
Apr 17, 2003 07:22 PM
