ls/vtec, stock bottom end anyone?
Old Sep 29, 2002 | 07:18 PM
Flexmyrex's Avatar
Default ls/vtec, stock bottom end anyone?
a friend of mine can give me his b16 head for a really good price. i need some help on deciding if i should put the head on the stock bottom without rebuilding it, or just wait (long time) till i get some more money for some high compression pistons and rods. how do you think it would perform just w the stock bottom end??
Old Sep 29, 2002 | 08:17 PM
OneThirtyEight's Avatar
Default Re: ls/vtec, stock bottom end anyone? (flexmyREX)
rasie your compression to 10.5-11:1 and get forged rods, thats all.
Old Sep 29, 2002 | 08:55 PM
brownshigh's Avatar
while you got it apart,mite as well do a mild rebuild.its only logic. compression upgrade would be nice too.dont forget about the other ls/vtec nessescities
Old Sep 30, 2002 | 12:20 AM
miller's Avatar
Default Re: ls/vtec, stock bottom end anyone? (brownshigh)
you can rebuild the motor a cheap but a good way to make decent power. get eagle rods , they are cheap but do the job for n/a cars, and get a set of ctr's. i would also invest in the z10 block girdle and you should be fine. that is a good budget build up that works.
Old Sep 30, 2002 | 12:53 AM
hionvtecxda6's Avatar
Default Re: ls/vtec, stock bottom end anyone? (vtecdoc)
don't forget about the oil pump. get a new vtec one.
Old Sep 30, 2002 | 01:14 AM
miller's Avatar
Default Re: ls/vtec, stock bottom end anyone? (hionvtecxda6)
oh yeah that also would be a good idea, why not put a prodrive in it. then you wont have to worry.
Old Sep 30, 2002 | 08:53 AM
Flexmyrex's Avatar
thnx for the input all.
is anyone here using a stock bottom in a ls/vtec setup, let me know.
[Modified by flexmyREX, 5:54 PM 9/30/2002]
Old Sep 30, 2002 | 12:24 PM
RenoRacing's Avatar
i had a stock bottom end in my ls/vtec for over 7k miles since april. it ran fricken amazing, all i had was gsr cams and a fpr and a chipped ecu and i could easily pull every gsr in a crx that i came across, i pulled a 92 hatch w/ gsr that ran 13.8's all day on slicks, it was great till my rings finally gave out last week, it's still not running but my friend has a good ls motor he's selling me and then i have my block that's in my car now to rebuild and also another b18 block with a bad rod bearing. i'm going to go with the ctr piston route with some total seal rings and call it good. you'll love it either way.
Old Sep 30, 2002 | 02:20 PM
Flexmyrex's Avatar
Default Re: ls/vtec, stock bottom end anyone? (HavokRacing)
thats exactly what i wanted to know , thnx havok.
Eg92civic
Dec 20, 2012 08:24 AM
dohdoh420
Feb 26, 2007 02:25 PM
PurleyMotor
Dec 1, 2005 10:11 PM
avividmemory
Oct 28, 2002 08:55 PM
MXPX
Aug 9, 2001 08:16 PM
