87' Honda CRX SI Questions
I just recently came across a 87 Honda CRX SI and I have quite a few questions.
First, The header panel is cracked, needs to be replaced. I found one place that actually sells them and yes, it's Ebay. I was curious, can you get the header panel and fenders in metal instead of plastic?
Also, the 91 CRX hood, would it fit on the 87 CRX with a little bit of modification?
And finally, are there certain things you need to do in order to get the rear end of a Acura Integra onto a 87 CRX?
Your best bet is to buy stock parts when you can find them, but most importantly, repair as much as you can. For starters, small dents on your stock hood are cake to repair, just use some bondo, or ask someone who knows the basics of body work to help, then re-spray it.
Thanks for the info crxguy, maybe you can help me with a few more?
Is there a solution to fix cracking of the header panel and the fenders? Like a film on the back side? Being new to the forums here and basically being unsure of anything on CRX's. I don't want to end up buying them again and having them crack.
I have more questions about the 87 CRX, I'm going to post pictures of the car here soon. The interior is all stock, only thing that really looks somewhat unpleasant would be the seats, small rips on the sides. Fixable.
The exterior has minor body damage. Front header panel is cracked in half (lost half of it while driving down the road, instant sad face). Left fender has small cracks leading from the bolts that hold it in place. There is only one quatersize rust spot on the back left side. The back plastic peice, trunk key hole. Best way I can describe it, that piece is cracked as well.
If anyone has a header panel or the back piece, I would like it.
. Trying to restore the car to the best of my abilities.
Thanks in advace!
. Trying to restore the car to the best of my abilities. Thanks in advace!
I'm pretty much repairing the same parts on my CRX as you are... you can check it out by clicking the 84 link in my signature.
CRXsiVROOM
Jul 7, 2004 07:48 PM
