GSR 94 ABS pump working constantly
Old May 8, 2011 | 01:20 PM
sikmansherman's Avatar
Default GSR 94 ABS pump working constantly
Hi everyone, today I changed out my ITR cluster and put a GSR back in there. The ABS light didn't go off, then I found there is a fuse missing and I put it back there, light is off now. But the problem is that the ABS pump keeps working once I start my engine, I can feel the brake pedal vibrates when I parked my car and press the brake. Sensors' problem?
Thanks a lot!
Old May 9, 2011 | 02:10 PM
Default Re: GSR 94 ABS pump working constantly
Bump! I pulled the ABS fuse now so the pump won't keep working.
Old May 9, 2011 | 03:03 PM
DA garbage's Avatar
You should hook up a scanner to it and read the voltage for each wheel. find out which one is not workin right and then do from there.
Old May 9, 2011 | 10:36 PM
Thanks! I'll try that out but what kind of scanner is it? ABS scanner?
It didn't shoot any code when I put the fuse back, just keep operating
Old May 10, 2011 | 01:48 PM
DA garbage's Avatar
yea if theres no ABS codes in it then u need a scanner that can read each tire on a data stream.
choithew
Aug 26, 2014 09:25 AM
darkwater_ghost
Aug 26, 2009 04:57 PM
momstaxi
Dec 9, 2006 04:21 PM
vxnine
Jul 24, 2006 05:33 PM
1-slo-2-cam
Jan 11, 2006 05:33 PM
