mpfi swap help!!!
Old May 8, 2011 | 10:32 AM
Atomic_EF9's Avatar
Default mpfi swap help!!!
ok so i did a mpfi swap on my 91 civic got it all hooked up and running
but my ecu is showing a code 10 how to fix this also the spark plugs are black and the car is running rich i need help to fix the thank you
Old May 8, 2011 | 01:23 PM
Atomic_EF9's Avatar
Default Re: mpfi swap help!!!
also im not getting a signal/power to my iat sensor
Old May 8, 2011 | 09:04 PM
redef90si's Avatar
are you running the Pm6 5spd si MPFI ecu?
Old May 9, 2011 | 06:58 AM
jlicrx's Avatar
maybe you have the wrong connector plugged into the IAT sensor - the correct connector is a 2-wire, white in color, and has one red with yellow stripe wire and one green with white stripe wire
Old May 9, 2011 | 07:20 AM
Atomic_EF9's Avatar
@ redef90si yes im running a pm6 ecu
@ jlicrx i have the red/yellow striped wire and green/white wire hooked up to it connector plugged into the IAT sensor the sensor tip is all brown does this mean its burnt? and how many volts or oms is the wires soused to put out?
thank you
Old May 9, 2011 | 08:54 AM
HAMOTORSPORTS's Avatar
Hopefully this will help diagnose it...
http://www.hamotorsports.com/intake-...re-sensor.html
Old May 9, 2011 | 09:57 AM
jlicrx's Avatar
thank you
resistance between the 2 terminals on the sensor should be between 1k-ohms and 4k-ohms - voltage on red/yellow wire should be around 5 volts - green/white wire is ground
Old May 9, 2011 | 09:18 PM
Atomic_EF9's Avatar
cool thanks the info is very helpful i will post again after i try that thank you
Old May 14, 2011 | 04:00 PM
Atomic_EF9's Avatar
@ jlicrx thank for that form it helped out a lot got the problem fixed it was a bad iat sensor
EtherEG93
Jul 3, 2008 06:15 PM
toolbox21
May 28, 2008 04:02 PM
LoudAccord
Jun 14, 2007 11:07 AM
bluez6
Jul 15, 2006 11:41 PM
89a6T
13
Jan 19, 2004 05:20 PM
