Difference in Integra quarter panels (LS,RS,GSR,Type-R)
I'm wondering if the quarter panels from an LS/RS are different from a GSR /ITR or are the Type-R quarter panels slightly different from the LS/RS/GSR?
LS:
RS:
GSR:
ITR:
Mainly from body line down around the area where the Type-R sticker is....it may be me but today i was looking at my boys R's at the paint shop vs my LS and it looked different......it might be a slight difference but it may not.
LS:
RS:
GSR:
ITR:
There are different ways you can see if there's a good chance any part might be the same between years or trims.
(1) Check dealership websites
Try looking on sites such as HondaPartsDeals.com (not sure off hand of the Acura site). Compare the part numbers. Remember just because Car A has a part with a different part number than Car B's part does not mean the part isn't the same or won't fit! Sometimes the part numbers for the original manufacturer change year to year or factory to factory. It could be a material difference or something else that won't impact the performance or fitment of the part. For example: '88-'91 Preludes have two different clock designs but both designs will fit any car, but you can't necessarily build one clock out of the different design type parts because the cases snap together differently.
(2) Check aftermarket suppliers.
You might find that an aftermarket part fits two different trim levels or even two different models. For example, del Sols and '92-'95 Civic hatches can use the same aftermarket mufflers iirc. This doesn't always mean the stock parts will fit, but it can give you an idea.
(3) Check collision part companies.
For body parts you might be able to find that a company makes one fender for multiple trims, years or body styles.
All of these aren't 100% foolproof unless the OE part numbers are the same, but it sure can help give you an educated idea.
Ditto the above^^^
GS-R... http://www.acuraautomotiveparts.org/...s=&view=normal
LS... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
RS... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal 94
That is the difference. The ITR quarters don't have holes in it for the moldings, like the GSR, LS, RS do. The ITR's fenders, doors and quarters are different than any other Integra, due to the others have side moldings.
True. But then they would have had to do all of the body mods too. Fill in the side moldings and what ever else they do to get that line down the side of the body to mock the R. The point I'm trying to make for the OP is, from the factory, all Integra's 94-01 excluding the Type R, had side moldings along the sides of the body.
92EG8
Sep 19, 2007 04:17 AM
