Honda S2000 Honda S2000
Honda dealer put GM GL-4 gear oil in diff and said its ok
Old May 7, 2011 | 02:11 PM
Kolyan2k's Avatar
Default Honda dealer put GM GL-4 gear oil in diff and said its ok
The manual says to use GL-5 or 6. Called dealer and they assumed me that GL-4 is just as good and they are not willing to change it.....
Need advice
Old May 10, 2011 | 04:43 AM
camoy's Avatar
Default Re: Honda dealer put GM GL-4 gear oil in diff and said its ok
More importantly you need to find out if the gear lube they put in it is the same one they put into CRVs. Early on some Honda dealers did this and caused a few diffs to fail. There is a service bulletin out for this exact issue. You can do a search for it the TSB # is 011001, basically it tells the dealer not to put in the stuff they use for CRVs. And that the correct type of fluid can be obtained from a Honda motorcycle dealership if need be.
If they aren't willing to tell you if it is the same stuff they use for CRVs and not willing to follow the TSB, then you will have to change it again yourself. This is one thing that you probably don't want to chance, since diff damage can occur from the use of the wrong type of fluid.
Old May 11, 2011 | 04:30 PM
Kolyan2k's Avatar
had more active discussion on this in another forum, but basically HoA didnt help, dealer refused to help, and they used GM GL-4 axle fluid (not CRV stuff). Changed to M1 75w90 GL-5 myself today. Maybe will sue the dealer for not following Honda's manual. This is just ridiculous.......
Old May 12, 2011 | 09:34 AM
Yuyodrift91's Avatar
You should have gotten all of that on paper.
If they claim it's just as good, then let them back it up in writing. That way if you had some problems thereafter, you had proof that they didn't follow the TSB. Your lawsuit may go a bit better too.
Old May 12, 2011 | 10:11 AM
Kolyan2k's Avatar
they dont want to put correct oil in diff., you think they will write me a letter
ps. this is a 3rd time Honda dealer screws with me.....1st when i wanted to buy a car...didnt.....2nd with my wife's Civic....they ended up refunding money for service, and now this.....
Old May 15, 2011 | 08:02 PM
(. )( .)'s Avatar
Honda sucks, no wait...i take that back. the people at the stealerships suck
TWSS-EF9
14
May 31, 2011 12:58 PM
phelpsj2
12
Nov 1, 2010 12:39 PM
95_Civic_4dr
Sep 16, 2009 10:05 AM
ericlee303
Dec 27, 2007 07:22 PM
kevotron
Jan 16, 2005 03:45 PM
