Suspension & Brakes Theory, alignment, spring rates....
coilovers moving freely while car is on lift???
Old May 7, 2011 | 09:12 AM
thompson4908's Avatar
Icon2 coilovers moving freely while car is on lift???
ok so i purchased my car with coilovers in it on stock struts (bumpy as ****) so i bought some tokico blues ( have yet to put them in )
now when i lifted the car up on a jack to put my rims on i noticed that the rear coilover springs and i guess its call a copler? ( the big screw looking thing that adjusts the height ) where moving freely and i can just move them up and down with my hand its not in tight like the fronts are
i was wondering if this is what its supposed to be like and if not is it cause i have the stock struts in there still ? they look like some pos coils probaly ebay ... any help would be greatly appreciated ive never done coils mostly just springs
PLEASE HELP!
Old May 7, 2011 | 09:56 AM
grumblemarc's Avatar
The Grumpiest
Default Re: coilovers moving freely while car is on lift???
They do that.
Old May 7, 2011 | 10:02 AM
oh thank god i was perplexed... now i can put my struts in
Old May 7, 2011 | 10:05 AM
psychoboy's Avatar
most of the time, they do that; tho i'm not sure it's the best option.
basically, your springs are too short when uncompressed for the application. looked at another way, your shocks are too long at full extension.
to properly fix the problem, you need an easily compressed secondary spring that will take up the difference between the spring length and the extended shock length, or you need a shock that doesn't droop as much when unloaded.
alternatively, you could raise the perches and the car, or you could find longer springs with more wraps and the same overall rate.
the quick and dirty fix would be a tether that keeps the shock from extending beyond the unloaded point on the springs.
Old May 8, 2011 | 10:46 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The coilover sleeves should have 2 perches that lock together, or a single perch with a locking bolt like Ground Controls. They should not spin freely even when the suspension is unloaded. If they do you need to tighten them up.
Also nearly all adjustable coilover setups will have springs that can move freely when the suspension is unloaded. This is not a big deal at all as the only time the suspension comes unloaded is when the car is raised off the ground (or when doing Dukes of Hazzard sweet jumps lol).
Also keep in mind that those Tokico HP blue shocks are just about as much crap as the original OEM shocks when using them with coilovers.
Old May 8, 2011 | 01:14 PM
Damn really ? So whhat would u recomend i get for struts because i havent installed them yet
NnN360
Acura TSX
Jun 27, 2012 05:30 AM
JrEk9
Suspension & Brakes
19
Nov 24, 2009 02:26 PM
mikeaitken
Apr 10, 2007 05:04 PM
jmoss1987
Jul 28, 2006 06:37 AM
mouseghb
Suspension & Brakes
Aug 2, 2005 12:49 PM
