Suspension & Brakes Theory, alignment, spring rates....
EK shocks on DC2 (non type R)
Old May 6, 2011 | 08:26 AM
zerovandez's Avatar
Default EK shocks on DC2 (non type R)
I have a buyer whos interested in buying my EK's AGX/H&R Sport setup. He has a DC2 non type r. He's concerned about the springs, and the mounting of the shocks. I'm reading that the fronts should fit. Can someone confirm? What has to be done to fit the rears? Since the lower shock fork is narrower than that from a DC2, I'd magine he would need to shave down the control arm bushing to make them fit. Am I correct? Are the top hats for the front and rears the same?
And about the springs; Mine are for a 99-00 civic Si. Would anyone know if they are the same length as H&R springs offered for the DC2?
Old May 6, 2011 | 12:04 PM
98civdx's Avatar
Master Detailer
Default Re: EK shocks on DC2 (non type R)
Your correct.
The fronts will bolt in, however, they are missing the bracket the needed to mount the break lines.
The rear shock mount bushing needs to be shaved down a little bit to make it fit properly.
skipper28-DC
Suspension & Brakes
Mar 2, 2010 12:21 PM
WilC4
Suspension & Brakes
Nov 9, 2009 03:56 PM
WilC4
Nov 6, 2009 08:49 PM
ebp_dc2
Sep 24, 2005 03:43 PM
