Transmission & Drivetrain Gearboxes, Differentials, Clutches
1996 Acura Integra GSR Clutch & Flywheel Install
Old May 6, 2011 | 07:48 AM
CaliforniaDad's Avatar
No-Traction = Fun
Default 1996 Acura Integra GSR Clutch & Flywheel Install
Over the last few weeks I have been having more and more issues with my clutch in my 96 DB8, harder to shift in and out of gears, slight scraping noise when trying to feather the clutch, random clutch chatter when going into the lower gears. I have come to the conclusion that the stock clutch disc must be coming apart (separating) I hope! So today I picked up a 4 puck sprung hub clutch with a 2600lb pressure plate along with a chrommolly 12lb lighted flywheel and will be pulling apart today. Pictures of the removal and install will come soon. Here is the clutch and flywheel I'm going to run.
Old May 6, 2011 | 05:49 PM
No-Traction = Fun
Default Re: 1996 Acura Integra GSR Clutch & Flywheel Install
Well I was right, Here is what i found when I pulled the trans out. Looks like one of the springs broke loose and a pc of metal was loose inside the trans.
Old May 6, 2011 | 06:03 PM
No-Traction = Fun
Here is kinda a photo step by step sorta.
Pulled it into my garage getting ready for the R&R
Dirty Engine bay!
Removed the intake system
Unplugged and removed the starter.
Upluged the speed sensor on the trans.
Old May 6, 2011 | 06:18 PM
No-Traction = Fun
Remove all the 17mm bolts that hold the trans to the block.
Unplug the backup light switch
remove both driver and pass axles.
Remove the 3 bolts that hold the half shaft in place.
remove the flywheel cover. 2 17mm bolts and 4 12mm bolts Also remove the shift linkage
Remove the front torq mount bolts
Remove the upper trans mount bracket, this is where you will need a jack to support the trans or in my case I had 2 people hold the trans when I removed the bolts. dont do what I did and forget to drain the trans fluid, I dumped it all on myself when we pulled the trans out.
And here you go, should look something like this.
now you can remove the clutch and disc. It should look something like this. In my case I replaced the flywheel,clutch & pressure plate. if you replace the flywheel make sure and use locktight. Tourq 79ftlbs
Old May 6, 2011 | 06:28 PM
No-Traction = Fun
Don't forget to install a new pilot bearing.
Install the new clutch/disc. use thread lock and tourq 19ftlbs
Now just do the process in reverse. make sure to refill the trans with fluid. I used Synchromesh.
Remove the upper fill bolt and fill until it starts to run out of the hole.
Well in my case the trans went back in and all my problems are fixed!!!
Time for the 500 mile break-in period.
Old Aug 13, 2014 | 11:53 AM
jayupark's Avatar
How is the clutch holding out?
Old Aug 13, 2014 | 01:15 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Do you even realize how many different engines have been in this car since this thread was created?
You would be better off just PMing him about the knock off clutch instead. He didn't have it in there for extremely long in any event.
Old Aug 31, 2014 | 09:43 PM
Sleeping Perfor's Avatar
Those cluch no good. Look what happen to my. Get stock with 2 and 1
https://www.dropbox.com/s/1dt574qlexu2k31/20140821_125637.jpg?dl=0
https://www.dropbox.com/s/xptldx398kd2ajh/20140821_125644.jpg?dl=0
https://www.dropbox.com/s/tld2207jvjcdtfm/20140821_125654.jpg?dl=0
https://www.dropbox.com/s/jls5bvblfmfydca/20140821_125701.jpg?dl=0
Old Sep 8, 2014 | 09:44 PM
Eg8Eddie's Avatar
Great read!
Old Sep 9, 2014 | 10:47 AM
whiteboy5150's Avatar
So i just replaced my clutch flywheel clutch slave an bleed it but it won't shift into gear while started only when off i put clutch in an 1st gear then turned it over an it jerked for word so clutch is engaged any ideas on what's wrong?? Please help asap
Old Sep 9, 2014 | 10:52 AM
Please help just installed new clutch, flywheel an clutch slave an bleed it an won't Goin to gear an ideas
Old Sep 9, 2014 | 03:23 PM
DO IT ON ALL FOURS
You should have made your own thread instead of bumping this old thread.
Either you put the clutch on backwards or didn't bleed the slave properly.
an2ny888
Sep 7, 2010 08:58 PM
IP RACING
Jul 15, 2007 11:44 PM
vishyncsu
Oct 7, 2004 10:38 AM
98Luder
May 5, 2002 09:19 AM
nugget8000
Aug 30, 2001 03:21 PM
