crx ignitor
Here's my ignitor. If anyone could tell me if mine is bad or not it would help out alot. Thanks[ATTACH]http://i1192.photobucket.com/albums/aa335/dylaxiin/ccdff1bd.jpg[ATTACH]
Disregard the white stuff, it's normal and doesn't affect the components functionality. Maybe try licking it, if it's corrosion it'll burn your tongue like battery acid - enjoy!
i just had the biggest diz. prob ever!!! lol
test the pins that the other guy told you too and the white wire BY ITSELF (not the one with nxt to the orannge!!) is the PGM-FI ecu wire (power and ground is connected latter down the harness) if that is bad the cel will stay on and there will be no power to thwe ecm (fuel spark.etc..) they are normally dont go out but if they do remember that ALL OBD0 internals are the same!!! (xcept DP-FI) B-series too!!! however the dual point icm is the same good luck pm me if you have further ???
Torridcivic
Audio / Security / Video
21
Jul 31, 2003 04:20 AM
Test the 3 terminal pairs on the big connector. Readings need to be 350 to 550 ohms between AB, CD, EF - done!
