Transmission & Drivetrain Gearboxes, Differentials, Clutches
Rebuilding 5AT transmission
Old May 5, 2011 | 03:30 PM
95dxsir2's Avatar
Default Rebuilding 5AT transmission
The car-06 Saturn Vue awd with honda drivetrain.
3.5 V6 with a 5AT transmission.
I disassembled the transmission to replace the carrier bearings and output shaft bearing. now i'm going back together and the case will only come as close as 3/8". the cir clip is already spread around the output shaft bearing. everything looks lined up. the reverse idler gear is meshing with the reverse driven gear and the 5th/reverse drive gear.
i've spent 3 hours trying to get the cases together. applied grease to all shafts that slide into the transmission case housing to check for alignment. checks ok. someone that has had one of these transmissions apart, please help . thank you.
Old May 6, 2011 | 11:14 AM
95dxsir2's Avatar
Default Re: Rebuilding 5AT transmission
nevermind.
Bob Dole!
Apr 20, 2025 07:42 AM
Cap'N Chronic
Jul 8, 2011 08:57 AM
EJ1B18c
Oct 3, 2009 12:06 AM
Mugen112
Sep 29, 2007 07:59 AM
Burke
Jun 5, 2003 03:38 PM
