PO 1457
I got a PO 1457 and 1457 PD today after driving the car 10 minutes in the morning. The code refers to a vacuum leak in the evap canister area. I suspect a hose might be the culprit and will be checking that later today. Anyone who has gotten this code before found anything else causing the issue? I am sure a canister is expensive to replace, not sure if I can buy the valve on the canister at autozone...
Year trim lvl please?
Ok I searched your code p1457 is evaporated bypass solenoid valve failure.
There is a factory service bulletin tsb 03-001
It affects 99-01 integras all models. Basically states evaporated bypass solenoid valve can fail due to corrosion caused by water getting inside the valve.
Hope that helps most likely its the solenoid valve.
Its a 2000 GSR, I guess if I take it to the dealer I pay for labor only since it is a TSB or for both labor and parts? If the latter, I guess I can buy the part and replace it myself. Thanks for the info. By the way, I checked the hoses and did not find anything, cleared the code and drove it for 30 minutes with no CEL coming on so it might be that the valve is just beginning to go bad and causing intermittent CELs.
Wazup
10
Apr 1, 2007 05:38 PM
mtfishin
Nov 8, 2004 06:35 AM
