CRX HF SWAP HELP????
Just addded a bigger intake manifold (d15b7) on my HF 1.5 8v. d15b6 and am seeming to have a little problem. the car runs good when pressing the accelerator at a calm pace... but when you try to floor it (mainly on 1st & 2nd) the car sputters quite a bit. The car also seems to have when I start it, right when I do the car seems to want to turn off for like 40 sec. right then the service engien light turns on and it gos back to working fine.
Just wondering if it can be the ECU or maybe the injectors.. any advice would be great HELP!
http://www.youtube.com/watch?v=nQ-oBu4GywU (This is one of the things thats wrong with it)
If its throwing an engine code, turn your ignition on and look at the ecu, it will blink red, count how many times it blinks and that is your code, you should be able to find out what it is, or tell me and I can look it up in my haynes manuel, if it has more then one code, it will blink the # of times for one, pause shortly and do it for the second, third, so on. To me it sounds like its flooding or dumping to much fuel, but I could diff. Check the engine code first and see what its saying.
Thanx slow91crxdx Ill check asap.. the sputtering stopped atleaste for now.. maybe it could of been that the injectors were dirty.. because its running smooth as i step on it.. but the engien still does the same thing when i turn it on.. ill be sure to check it out.. any pics as to where i can see that red light on the ECU would be great!?!?!?
Thanx for the info everyone heres another vid just for a little more detail
http://www.youtube.com/watch?v=4Pk0rbslFUo
i checked it but its trowing all kinds of codes now and rewired everything back so now i gave all four injectors going to the ecu and the injector box i have going to the ecu too.. Now i looked at the ecu and it say 3 7 10 and 14 for the codes and im hella lost
I'm Jealous I want an HF lol, r90crxhf, did you check the ecu to see what codes its throwing? And EFsmallzz what year and model is yours? And I can tell you the codes if its a ef with a d-series motor.
OK I checked the led light (engine code) and it blank: 1-2-3-4 (pause) 1-2-3-4 (pause) 1-2-3-4 (pause)...etc etc... Ill post a video later if this doesnt tell you much :/
http://www.youtube.com/watch?v=FboUHtZOatc
OK so I messed up its 1-2-3-4-5 (pause) 1-2-3-4-5 (pause) etc etc... anyone know what code this is????
niceguy12
Jan 3, 2005 07:01 PM
Bongnak
Jan 10, 2004 06:34 PM
shift6
Nov 13, 2002 11:26 AM
