VA '98 Adriatic Blue Pearl Integra (Built, Sleeved, Boosted)[Sleeper]zzzz
Old May 4, 2011 | 10:14 PM
GingerBread Man's Avatar
Default '98 Adriatic Blue Pearl Integra (Built, Sleeved, Boosted)[Sleeper]zzzz
Means of contact: Email Dvalle051@gmail.com or Call (571)294-9372
Price: $9,500 O.b.o (with everything) -or- $7,500 o.b.o (No Turbo Kit, just the Built motor (all motor) set up that makes roughly around 210-215whp)
Shipping: Can have the car shipped any where in continental US at buyers expense.
Interior shots are located at the bottom of this page.
NEW PRICE --------> $9,000---------->Now the price is $8,500
Car can be bought without the built motor/turbo set up, Just a stock B16 with a the shell for $5,000
Description: 1998 Adriatic Blue Pearl Integra. 3rd owner. I've had this car for a little over 5 years now. Done all that my heart desires to this car. I've pampered this car from day one, I just don't have time for it anymore. The current setup has 4,5xx Miles clocked as of today and 106,5xx Miles on the Chassis. I'm selling this car to fund my business and get my life started. Please Don't Hesitate to call or email about any questions. All paperwork is at my side to show that this is a legitimate build.
B18b Block...
Bored to 2.0
Darton Sleves
Micropolished and Balanced Knife Edged LS Crank
C.P. 9:5:1 pistons
Eagle Rods
ACL Bearings
Type-R Water
Type-R Oil Pump
Type-R Timing Belt
Blue Print & Balanced by InlinePRO
Half Size Aluminum Dual Core Radiator (Custom Mounting Bracket Done by Ramey Built)
Spal Cooling Fan
Hasport Mounts
B16A2 Head....
3 Angle Valve Job
InlinePRO Valves
InlinePRO Springs & Retainers
Type-R Cams
InlinePRO 5 Bolt Adjustable Cam Gears
Password JDM Cam Seal
Edlebrock Victor X Manifold Port matched 70mm
Edlebrock Victor X Throttle Body with adapter Plate
Turbo Setup...
Precision 6262 Journal Bearing, T4 housing. V Band
Inline Pro T4 Turbo Manifold
Tial 44mm Wastegate
Tial 50mm BOV
Precision 750hp Intercooler (Flat Black)
Vibrant Performance Silicon Couplers w/ T-Bolts
Custom IC Piping done by Ramey Built
Custom Dump Tube done by Ramey Built
InlinePRO SS Downpipe (T4) w/ V Band Clamp
InlinePRO SS 3 inch Turbo Back
Vibrant Performance 3 inch Flat black muffler
Earl's Stainless Steel Braided Return Line
Earl's Stainless Steel Braided Feed Line
Tranny...
'98 LS Tranny
Centerforce Dual Friction Disc 4 Puck Sprung Clutch / Pressure Plate
Fidanza 11 lbs. Flywheel
Earl's Stainless Steel Braided Clutch Line
Type R Slave Cylinder
Type R Master Cylinder
Fuel...
Siemans Deka 900 CC High Impdance Injectors (No Resistor Box or Injector Driver)
InlinePRO Fuel Rail (Black)
Aeromotive A1000 FPR (Not Installed)
Earl Stainless Steel Braided Fuel Filter Line
Walbro 255lph hp fuel pump
Electronics...
Hondata s300 with Boost Option/ Boost By Gear
AEM UEGO Wideband
AEM TruBoost Boost Controller
MSD Ignition Blaster SS (installed, just needs MSD Distributor Cap)
GM 3 Bar Map Sensor
Stopping...
Dunlop Direzza Z1 Star Specs
Brembo Slotted Rotors (Front)
Brembo Blank Rotors (Rear)
Hawk HP plus pads (All around)
Earl's Stainless Steel Brake Lines
Suspension...
Hayame 1 Piece Coilover :8kg/mm (Front) & 10kg/mm (Rear) (Rides real smooth)
Allen Built Motor
Tuned By InlinePRO
Old May 5, 2011 | 07:53 AM
Default Re: '98 Adriatic Blue Pearl Integra (Built, Sleeved, Boosted)[Sleeper]zzzz
Interior shots coming soon!
Old May 5, 2011 | 09:04 PM
b U m p
Old May 6, 2011 | 06:07 AM
srt4mike's Avatar
Bump for viewing.
Old May 8, 2011 | 08:58 AM
Mothers day bump
Old May 9, 2011 | 09:27 AM
up TOP ^^
Old May 11, 2011 | 03:08 AM
Interior Shots
Old May 11, 2011 | 11:00 AM
Bump this....
Old May 12, 2011 | 08:07 AM
Bump
Old May 13, 2011 | 10:17 AM
New price is up, I'm a motivated seller. Someone take advantage!!
Old May 13, 2011 | 10:36 AM
bb6kid22's Avatar
trades?
Old May 14, 2011 | 04:30 PM
Pending Sale.....
matt97lude
Mid-Atlantic (Sales)
Sep 6, 2012 05:14 PM
GingerBread Man
15
May 11, 2011 03:03 AM
SlowVtecCrx
Dec 24, 2006 05:30 PM
justagsr
Dec 3, 2006 06:14 PM
Maybomb119
Aug 26, 2002 12:59 AM
