Full GSR swap w/68k mint. + B-series parts +hondata s200
Full GSR swap w/68k out of a 2000 Gsr with legit papers. Engine, trans, wiring harness, axles, ecu,dizzy,mounts, shift linkages ,everything you need. motor and trans is fresh Full GSR swap w/68k out of a 2000 Gsr with legit papers. Engine, trans, wiring harness, axles, ecu,dizzy,mounts, shift linkages ,everything you need. motor and trans is fresh $1850
Also have:
Hondata S200 w/boost options $250
2000 SI B16A head with Skunk2 springs+ retainers $425
ACT clutch kit HDR6 w/lighten flywheel (slightly used) B18c $175
Call or text 3014550225
Also have:
