How to tell if RSX mirror is heated?
Old May 4, 2011 | 03:49 AM
jdmcivicferio's Avatar
Default How to tell if RSX mirror is heated?
Is there a way to tell if the mirrror is heated or not? Also how many wires should the mirror be if it is heated.
Thanks,
Old May 4, 2011 | 06:03 AM
Mr. Spade's Avatar
Default Re: How to tell if RSX mirror is heated?
Thanks,
Press the button, put hand on mirror
Old May 4, 2011 | 09:20 AM
JDMxTai's Avatar
I don't think it would genorate enough heat to feel it.
Fog it up with your breath and see if it goes a way ten mins after its on.
Old May 4, 2011 | 11:56 AM
aemciv's Avatar
I think he means how to tell off of the car. Looks as though the plastic holder around the glass element is an identifier.
http://www.clubrsx.com/instructions/...tedmirrors.pdf
Old May 4, 2011 | 03:14 PM
Mr. Spade's Avatar
It does.
Old May 4, 2011 | 04:51 PM
Bright13's Avatar
A friend of mine has a '96 3.2Tl, I'm sure they're slightly different, but the mirrors get hot if they're left on, and unlike some of the other features they don't turn off when the cars turned off, well they turn off, but come on again when the cars started again, unless manually turned off. Kind of annoying, but I assume theyve fixed that since then.
Old May 4, 2011 | 05:11 PM
lazlong's Avatar
Shouldn't it be a 3 wire connector instead of 2 wires?
Last resort, you can take the mirror off the actuator and see if wires are hooked to the mirror itself.
Old May 4, 2011 | 06:30 PM
I'll figure it out on my own.
hoppin blox
Paint and Body
Mar 30, 2013 10:08 PM
no1_suspek
Honda Civic (2001 - 2005)
Nov 23, 2011 06:10 AM
Jap_Spec_Imports
Mar 26, 2008 05:01 AM
david11
Jun 12, 2007 11:11 PM
