ef sedan bseries swap
Old May 3, 2011 | 03:21 PM
JDM_ED6's Avatar
Default ef sedan bseries swap
can u slam a ef sedan with bseries swap just a low as u can if it has a single in it? same question about hatches.
Old May 3, 2011 | 03:22 PM
Aesthetic Gains's Avatar
Dos Pupusas
Default Re: ef sedan bseries swap
Werd.
Old May 3, 2011 | 04:29 PM
codybuRr's Avatar
sure why not, just becareful not to hit the potholes it can throw a hole in that nice oil pan
Old May 3, 2011 | 07:25 PM
Clipsed's Avatar
B series hangs lower than a d so no you wouldn't be able go also the b series is heavier ad well so stiffer springs would be needed to be low so as not to bounce your header or oil pan on the ground.
ZCHondaCRX91
Jul 12, 2015 08:07 AM
sitinthehall
Mar 5, 2007 07:28 PM
