IM going K so b series& jdm parts need new owners
ok guy i have to get rid of all my b series parts im going k so no need for this parts no more sold my hatch also and starting a new project
PRICES DO NOT INCLUDE SHIPPING BUT WE CAN WORK SOMETHING OUT!!!!
*98 GSR block with 88k vin number still in place asking SOLD
*92 sir b16a block from hmo less than 2k
B16a rods
ctr pct-.25mm oversized pistons
n1 crank pully
polished crank
balanced crank
itr oil pump
oem water pump
oem timing belt
pw jdm oil magnetic drain plug
arp head stuts
i have paper work for the bottom end built asking 1000 obo
PARTING OUT THE HEAD TO GET THIS MOVING A BIT FASTER
*B16a Sir head HMO less than 2k
ported
3 angle valve job
golden eagle cam seal
omni valves
omni springs
omni retainers 600
buddy club stage 3 cams/buddy club cam gears gold edition SOLD
golden eagle fuel rail/fuel pressure regulator 180
blox intake manifold 150
rc 310 injectors 150
hondata intake manifold gasket 35
vtec solenoid 60
new b series dizzy no miles on it 200
ngk spark plug 20
*gsr flywheel with ACT pressure plate and clutch SOLD
*chipped p28 b16 base map SOLD
*obd2a to obd1 SOLD
*p06 no casing 20
*CTR base plate with seeker wing with alex bracket for ek hatch 400 firm *priced lowered*
*98 gsr vtec solenoid SOLD TO ib3nan ONE MORE LEFT
2 b series compressor 40 each
2 da post mount bracket 20 each 1 left
obd1 alternator 40
obd2 alternator with aem pulley 80
b series steering pump with bracket SOLD
b series starter SOLD
half shaft SOLD
b16b front trans mount with bolts 35
96-98 hatch tail lights 50
96-00 passenger door shell manual no dings 80
if you dont like the prices throw me and offer and we can work something out BUMP IF VIEW ALSO
B16a rods
n1 crank pully
polished crank
balanced crank
itr oil pump
oem water pump
oem timing belt
arp head stuts
ported
3 angle valve job
omni valves
omni springs
omni retainers 600
vtec solenoid 60
ngk spark plug 20
*obd2a to obd1 SOLD
*p06 no casing 20
2 b series compressor 40 each2 da post mount bracket 20 each 1 left
obd1 alternator 40
half shaft SOLD
