FS: B-Series Turbo Kit Complete
Hey guys and gals i am selling this kit because i had planned to boost my LS motor that i rebuilt last winter but things went wrong and now i gotta rip the motor back apart to get the block and head straightened out, i never got the chance to put the kit on and run it i only took a boutple pictures with a mock setup so most of the kit is still brand new, some is used i will list that when i list the parts. but then with short time on my hands i just swapped a B20 with a 93 gs-r short geared cable trans into my integra instead of re-doing my LS which is also for sale, what happened was when i rebuilt it i only resurfaced the block cause all the clearances were still good but like an idiot i used a sanding disc instead of a resurfacing disk. SO basically the head gaskets out of it. The good is: Toga Race rod and main bearings, ARP main,rod, and head bolts, all new bottom end gaskets. didnt burn oil or anything. I never overheated it, just burned a lot of coolant so if you have the time to rip it apart and get it milled ($35) then it's yours for $450. also i have the B-series LS trans for sale seperatley for $300 with an ACT 6 Puck Clutch, stage 3 pressure plate and ACT throwout bearing, the trans has about 150K on it. if your interested in both then for $650 they are both yours. Everything worked and ran when i pulled it this past winter. NOW on to what the title states, instead of explaining the kit, here's the list of what i have and descriptions. NO PARTING OUT!! I am selling this kit as a whole and will ship as long as you pay full shipping expense or will accept pickup, i am asking $900 OBO for the kit:
-TD05 16G Turbo Ported to a 20G - NEW
-B-Series Turbo Manifold, XS Power, the new style with the braces - NEW
-Turbo Downpipe - NEW
-BOV tube with screws and gasket - NEW
-J-Pipe - NEW
-All Gaskets w/ steel flange for downpipe i got seperate in case i needed to do a custom exhaust - NEW
-Walbro 255lph Fuel Pump - NEW (For 1990-1993 Integra)
-Blitz BOV - NEW
-Oil feed and return lines with adapters, gaskets, and fittings. Were installed but never used - LIKE NEW
-Oil sandwich plate (not shown, still on motor) - USED
-Oil Restrictor (On Turbo) - NEW
-DSM 450cc Injectors w/ pig tails - NEW
-Front mount intercooler - USED
-Manual vaccum boost controller with vaccum lines, misc. bolts, screws, nuts, gaskets, banjo bolts, and studs for the kit - NEW
-Misc. Piping that came with the kit 2.25", 6 blue couplers, and 12 t-bolt clamps - NEW
-Universal triple guage pod - NEW
-Faze Boost guage w/harness - USED
-AEM Air Fuel ratio gauge with O2 sensor, O2 fitting for exhaust, interchangeable faces, and harness - USED (about 2K on it)
I have Pictures of everything listed so let me know if you wanna see anything individually
-J-Pipe - NEW
-Blitz BOV - NEW
Bump you should just boost the b20. -this is James by the way
My four door will hopefully be boosting soon. let me know if you part out the turbo kit I need a few things.
IntegraLS90
Apr 25, 2010 09:55 AM
Tyconway
Feb 9, 2009 10:41 AM
aziantegger10
Sep 29, 2006 09:16 AM
luis666
Jun 22, 2006 04:52 PM
