need some honda heads to pick** DA problems
Old May 2, 2011 | 04:40 PM
djkobe's Avatar
Default need some honda heads to pick** DA problems
first off i would like to thank anyone that gives me some good information because i have been working on this car for almost a month and spent a lot of money as well.
im an automotive major so im very comfortable working on my own car and have a few brains to pick but i come to you honda-tech looking for some honda heads to bounce some ideas off.
BACK STORY:
car is a 90 da9 with stock "fresh rebuilt" b18a1, it drove perfect tell a month ago when i was driving home from class on a very low tank. It started bogging down as if a plug wire had come undone of as if it wasnt receiving any spark/fuel. i first thought i had ran out of gas and put a few gallons into it and checked for fuel pressure which it had plenty of. tried cranking and thats all it would do, everything turned over but no fire. it sounded kinda like it may have skipped a few teeth on the timing, so i got it home and sure enough the old stretched belt had skipped so i pulled the head to make sure no valves got bent and clean it up and replace valve seals, everything checked out and was properly reinstalled. while the head was off i cleaned up the old main bay loom and replaced a few rotted wires (1 by 1 to make sure all was good, as well as having diagram to double check). i also replaced the battery ground with some 4g and new battery cable with all new terminals.
After i cleaned and re assembled everything i put on a brand new water/tensioner/ tensioner bolt/ timing belt, thermostat and a few other coolant sensors. I reconnected all of the coolant lines and wiring, filled it with coolant and oil and tried starting it up and all it would do is crank AGAIN. broke out the fuel pressure gauge and it checked out, so i checked plugs for spark and nothing. i traced every wire/fuse/ relay that was in the start/ignition circuit and everything was good, so i checked the actual cap and found that i was missing the screw that held the rotor in place so i got a new cap and rotor, must have fallen out in the abyss of my garage. Tossed on the new stuff and cranked, still just cranking. checked for power in the dist. everything was in spec so i checked the coil and it seemed fine but i got a new one from autozone and had them test the icm, all good and still just cranking. while getting very frusterated i double checked the timing again and made sure that i was on TDC of compression stroke and all was good cams were spot on with actual marks not the pully lines. after making sure everything was spot on i got it to fire up very rough for a few seconds but i shut it off because it didnt sound right and i tossed a code 4 for my CKP sensor. i bit the bullet and bought a kragen distributor and put it on yesterday and it seemed to be cranking normally with out this, best way i can describe the sound is "an unbolted exhaust manifold slamming against the bay and block". it didnt try to fire up and was acting as if it was out of gas (which was very low still) so i put 5 gallons in and tryed cranking it and the "doom sound" was back.
im sorry for the long post with crappy spelling and horrible grammer but im starting to get desperate and very aggrivated due to this being my only car so its difficult to get 2 and from school/work. thank you all in advance for any helpfull insight to getting my baby back on the road
Mcbrizzle
Oct 6, 2014 05:08 PM
RedLine1975
Jul 17, 2012 05:43 AM
alvingan
Mar 18, 2012 08:45 PM
SpOoLiNg CiViC
Jan 13, 2007 04:12 PM
EOE
Nov 9, 2005 05:06 AM
