Vacuum line routing
So I've been looking at all the diagrams and trying to cross reference them. So I wanted to ask to make sure.
I have a 93 Del Sol, all the vacuum lines are in the right place except for one that comes of the charcol canister.
My motor is a 99 b18c1 that was converted to obd1.
so does this vacuum line, go to the port near the throttlebody that has the nipple cover on it?
Here is the capped of nipple.
and here is the plugged vacuum line from the canister.
Thanks
Thanks
honestly i would just get rid of the charcoal canister. but i believe that hose connects to a hardline hose running along your firewall. there is two hard hoses one is a bigger one that the canister hose connects to the other is your gas line. hope this helps
Removing the canister is a big no no especially in smog **** california.
im pretty sure both other lines are going to the right places, but i will check later.
3 hoses on the EVAP canister:
1. from the fuel tank to the EVAP canister
2. from the EVAP Purge Solenoid mounted on the intake manifold to the EVAP canister
3. (the one you are holding in the pic) from the EVAP canister to a vacuum port on the intake manifold plenum.
Plug that hose into the capped off vacuum port in the pic.
