code 16 help!!!!!!
88 civic dx automatic : d15b2 dpfi
main relay clicks
fuel pump primes
injectors click
car starts
idles rough and ecu gives code 16 im stumped timing is set too 18btdc
main relay clicks
fuel pump primes
injectors click
car starts
Yeah but there are different connections for the different prongs on that main relay, just because the fuel pump primes, does not mean that the other connections are connecting properly.
I always take out that 10mm bolt to where the main relay is attached under the dash because I know sooner or later that main relay will give me an issue.
Whats the harm in trying to see if another one gives you the same issue? *shrugs*
Here is the Factory Service manual flow chart. Maybe this will help. Good luck.
thanks same flow chart im reading too i wanna check the resistance for the injectors but its dpfi which is main and auxiliary injectors do you know if the resistance range is the same.
The injector resistance should be 1.5-2.5
Yeah I wasn't sure if you had the flow chart or not, figured it may give some insight to it.
Maybe also check your thermostat housing ground make sure it's making good contact.
Also according to the main relay fix website, says that usually when you get code 16, it's because the ECU isn't getting proper power to the main relay. This is why I would def check your ground at the thermostat housing.
http://techauto.awardspace.com for your reference.
i love that site
well i pulled the main relay it does look like it needs to be re soldered for sure. crazy thing today i reset the ecu and the code didn't come on. the car idled smooth and drove smooth it wasn't until i came back and tried to start it again that the code came back the car started on the third try is when i decided to pull the main relay.
checked resistance top injector was like 8.1 bottom was 1.7 looks like the top one might be done if thats the case. hmmm maybe i should send them in to be cleaned and refurbished?.
t-stat ground makes contact good i mean to be on the safe side i can dremel the surface but its good.
guy in a jetta
Nov 7, 2017 12:05 PM
whiteformula98
12
Jul 29, 2015 12:58 PM
B18 CYA
15
Sep 16, 2006 12:04 PM
