b16a del sol cranks but wont turn over. HELP!!!
Old May 1, 2011 | 06:05 PM
B16a_delsol94's Avatar
Icon2 b16a del sol cranks but wont turn over. HELP!!!
so ive got a 94 del sol with a obd1 b16a. so basically my problems is my car wont start sometimes, especially when its cold or its been sitting a while but i went to start it today at around 1 with temp. above 45' and it started right up. when it doesnt start i can push start it and it runs fine. i have replaced the dizzy, ignition module and the ets. i need to get this car going so any ideas help. thanks!
EDIT: The CEL isnt usually on but i did the jumper plug thing so i could check for codes and i got a #6 which is water temp sensor and a #8 which is top dead center sensor
Old May 2, 2011 | 12:17 PM
saywhat's Avatar
Default Re: b16a del sol cranks but wont turn over. HELP!!!
Check your main relay.
Old May 2, 2011 | 10:57 PM
phorse's Avatar
it might be your ecu...had the same problem...my car wouldnt start in the morning or in cold temp...and when the sun came out it would start right away...then it stopped starting...i changed the dizzy and nothing...then i changed the ecu and bingo...lol so check your ecu...
1point8DelSol
Feb 24, 2013 08:48 AM
joshsdelslow
Sep 2, 2011 04:46 PM
cachase1
Feb 26, 2008 08:21 AM
YEL-MEL
Jun 23, 2003 05:52 AM
