1991 Civic DX 1.5 L refused to start
Old May 1, 2011 | 05:47 PM
DennisWaller's Avatar
Icon6 1991 Civic DX 1.5 L refused to start
This well maintained car invariably started and ran well after complete engine overhaul 20K miles ago when master relay, O2 sensor & fuel filter were replaced with OEM parts. Engine unexpectedly refused to start one morning. Engine turns over properly and cylinders fire irregularly but never enough cylinders to start engine. Acts as if engine is fuel starved. Fuel pump heard to operate for two seconds after ignition turned on; check engine light goes out as soon as starter engaged; no codes set on ECU. Shop manual suggest checking ECU but I don't have the test harness or a known good ECU to substitute.
QUESTIONS:
1) Does anyone know how the cold start fuel enrichment cycle works on this car and how I could test for a problem there?
2) What additional tests should be performed to rule out ECU problem? Given age and low value of car buying a replacement ECU is uneconomic.
Dennis Waller
denniswaller@comcast.net
Old May 1, 2011 | 09:10 PM
rudyndrew's Avatar
Default Re: 1991 Civic DX 1.5 L refused to start
Thats a tough 1 but ecu's usually don't go out that easy.
fsjeep
10
May 12, 2020 06:12 PM
jvaldovi
25
Sep 21, 2016 10:22 PM
zzyzx9
Honda Civic (2001 - 2005)
Jul 2, 2012 06:28 PM
bare
15
Aug 13, 2005 06:23 PM
