need help deciding what axles/halfshaft i need.
Old May 1, 2011 | 10:55 AM
coquieg6's Avatar
Default need help deciding what axles/halfshaft i need.
have a 1996 Automatic integra,and have converted an LS motor and GSR transmission. What axles and halfshafts do i need??
Trust me guys ive searched everywhere and i just hear conflicting arguments.
1. i Have an Automatic halfshaft, would it work at all?
2. Im right now leaning on a all GSR axles and halfshaft. bu if i can save money on the half shaft that would b awesome
Help would be appreciated.
Old May 1, 2011 | 01:20 PM
coquieg6's Avatar
Default Re: need help deciding what axles/halfshaft i need.
ne ideas suggestions??
Old May 1, 2011 | 04:14 PM
fonkernuckle's Avatar
If i recall correctly the only difference in b series axles and halfshafts are: either abs or non-abs and 90-93 DA have a female ended halfshaft (so you cannot use the driver side axle if the axle is 94 and up) and 94-01 have the male-ended halfshaft.
Right now I have 94 ls axles and halfshaft on an ls motor and going into a gsr trans (5 speed) no problem.
So you do not have to buy anything. Try them and see if its not true.
Old May 1, 2011 | 05:31 PM
coquieg6's Avatar
awesome, this helps a lot. One more thing, do you think the automatic Halfshaft would work w the Manual axles??
Old May 1, 2011 | 06:49 PM
Yeah, axles are the same as well as halfshafts its just DA versus DC thats why on H-T Marketplace you never hear whether the axles and halfshaft are from automatic or standard.
FYI same thing applies to civic axles (of course no halfshaft used)
Old May 1, 2011 | 07:13 PM
fcluddington's Avatar
I dont know how much power you plan on running or if you are just trying to get car moving. Advance Auto will warrenty the axles for 1 time maybe 2. New axles dont cost that much btw.
Old May 3, 2011 | 10:04 AM
coquieg6's Avatar
i plan on running tha stock LS grand total of 140 bhp lol., ya ima prob do that for tha axles, im just concerned of the halfshaft cus it was an automatic and now its manual, i guess ill try an find out.
Old May 3, 2011 | 07:14 PM
if the half shafts are the same part number you have nothing to worry about. inspect and install. I would say the half shaft is the strongest part of the driveline.
lsvtecboi'95
Aug 3, 2007 10:01 AM
boostedSI90hatch
May 25, 2006 09:39 AM
HamiltonRex
Feb 22, 2006 03:58 AM
girliehonda
Apr 24, 2005 02:03 PM
