OBD1 B series Vtec distributor compatible on D16?
Old May 1, 2011 | 08:54 AM
Spoon84's Avatar
Default OBD1 B series Vtec distributor compatible on D16?
Ok guys i've searched and can only find people talking about d16 dissy's on B series Vtec's but not vise-versa.
I got the b series vtec distributor mounted up on the d16. It fires up but is running rough then shuts off when gas is applied. Since i just put this swap in i don't know what other flaws the motor could have. Runs rough as if it were the IACV. Loud ppssssssss noise from the little hole in the T.B. when running.
But does anyone actually know if a b series vtec distributor will work on D16?
Any help is appreciated. Thanks
Old May 1, 2011 | 09:23 AM
94EG8's Avatar
Seagull Management
Default Re: OBD1 B series Vtec distributor compatible on D16?
It's possible, but more likey the timing is different.
Old May 1, 2011 | 09:55 AM
apexi_rsx's Avatar
ive done some reading and searching. it seems it will work only one bolt will line up and it will work but not recommended.. usually people do this temporarily
Old May 1, 2011 | 06:16 PM
Spoon84's Avatar
Works fine guys.. It was a case where the gas was bad.. Fresh gas and the swap started up perfectly. Thanks for your input.
dapump2003
Jul 17, 2007 08:47 PM
Dabber
Jun 29, 2007 11:24 AM
Spence
Northwest (Sales)
Nov 29, 2005 08:17 PM
jdmcivicferio
Sep 25, 2003 11:28 AM
