Quick Question JDM D15b
Old May 1, 2011 | 08:46 AM
Unphzd's Avatar
Default Quick Question JDM D15b
Would a Stock Civic DX hatchback 1996 Manual Engine Harness work as plug and play for a 1997 JDM D15B 3stage vtec with some plugs such as vtec and egr needing to be manually wired?
Finally got a job at honda and discounts are nice so im planning to replace my crappy spliced up harness.
Old May 1, 2011 | 09:34 AM
94EG8's Avatar
Seagull Management
Default Re: Quick Question JDM D15b
Yes, plug and play other than wiring vtec and EGR.
Old May 1, 2011 | 02:15 PM
Unphzd's Avatar
Thank you.
Old May 1, 2011 | 02:56 PM
apexi_rsx's Avatar
the 3 stage vtec isnt going to work running a y8 ecu. you would be better off swapping to a y8 or z6 head then trying to find an ecu to run the 3 stage vtec. they are hard to find
Old May 4, 2011 | 05:32 PM
Unphzd's Avatar
i have the p2j ecu :] thanks to hmotors
Old May 4, 2011 | 05:36 PM
dirvin7588's Avatar
damn, u suck to get the ECU haha i just got my D15B n had to use my Y8 head
Old May 4, 2011 | 05:52 PM
ElSapitoH22's Avatar
id manually wire it in then just have someone tune it throu... re-map the 3 stage?
uindaway
15
Nov 4, 2012 05:23 AM
n_senn
21
Aug 3, 2011 07:30 AM
elmalouno
May 31, 2011 08:52 PM
dirvin7588
32
May 16, 2011 11:10 AM
EK k kay
Nov 18, 2004 11:18 AM
