Ma/FS: Drag Cartel....CC Twin Disc...Built K24...Etc..
Old May 1, 2011 | 04:23 AM
MassScene's Avatar
Default Ma/FS: Drag Cartel....CC Twin Disc...Built K24...Etc..
Location Is Boston, Ma.
I recently sold my car and im now selling everything i have left.
If your interested in pics then please PM me / Serious buyers ONLY..Thanks
I JUST WANT TO BE SUPER SUPER CLEAR THAT I DO NOT WANT ANY TRADES FOR UR D/B/H/K -SERIES PARTS @ ALL !!!
THE ONLY TRADE ID BE INTERESTED IN MAKING IS FOR A COMPLETE 99/00 SI OR A WHITE 4-DOOR GSR .....OBVIOUSLY IT WOULD BE DEPENDING ON CONDITION/ ETC..
I have a 02-04 Type-S head that i purchased from Checo on k20a.org. He can also be found on youtube under that name as well. The head has roughly 50 miles on it. Drove over 4 Hours to buy this head.
The head was completely done by Drag Cartel. It is suppose to be 1 of the last "Hand Ported + Polished" heads that Jeremy did. The head has OS 36mm Intake / 30mm Exhaust Flat Faced Valves. The head has complete Supertech valvetrain. Has complete set of rockers. Also sold with 50Deg. RBC cam gears. And water outlet passage.
The head was bench flowed @ 356 cfm @ .600 lift. I do still have the original chart/ sheet from when the head was done for proof. The head is 100% ready to go and make Big Boy power. Looking to get back what im into the head for / Ive never even got to use it or install onto my block its been wrapped up in my daughters room for months. Price is set at $2,150 Shipped with everything listed above.
I also have a BNIB Competition Clutch Twin Disc for K-Series. The box has only been opened to have my machine shop balance the Flywheel + Pressure Plate. 100% Ready to go $1050 Shipped.
06' K24 Accord Block. Will provide the VIN # to serious buyers..Im SUPER SUPER **** and ran a Carfax before i took the 4 hour ride to go purchase the block so i know its LEGIT.
TSX Crank
Acl Race Bearings.....Thrust/Rod/Crank
BluePrint Racing H-Beam Rods
Supertech 88mm 12.5.1 compression Pistons
Toda chain tensioner
BluePrint Racing Head Studs
K20 Type-S Oil Pump Modified
K20 Type-S Water Pump
K20 Type-S Alternator
Crv Steel Oil Pan
K24 Timing Chain
Block was just Decked .006 / Freshly Honed / Hot Tanked w/ 0 Miles
EVERYTHING Was Balanced: Crank/ Pistons/ Rods "BOTH ENDS"/ Crank Pulley
Block is 100% ready to be matched with a good head and make 300+whp
Price for the block is set @ $2500 with everything listed above.
I also have a BNIB Cometic K20/24 Head Gasket .036 / 88mm Bore $85 Shipped.
Last on the list is a RBC Intake Manifold....Yosolo Made...I purchased from a local guy that ran 10.8 and made 315whp with this manifold on a NON PORTED Head !
The intake plenum was cut open and rolled back to extend the plenum size a good 35% larger than OEM .....aluminum was made to fit and welded back into place making the plenum ready for just about anything you can put this intake mani on. It also has a 75mm Mustang Flange on it now to accept much larger TB' s.
Price is set at $525 Shipped.
Old May 1, 2011 | 01:55 PM
MassScene's Avatar
Default Re: Ma/FS: Drag Cartel....CC Twin Disc...Built K24...Etc..
BuMp.....TtT
Old May 1, 2011 | 07:20 PM
MassScene's Avatar
BuMp....TtT
Old May 2, 2011 | 02:24 AM
MassScene's Avatar
BuMp...TtT
Old May 2, 2011 | 11:39 AM
MassScene's Avatar
BuMp.....TtT
Old May 2, 2011 | 04:10 PM
MassScene's Avatar
BuMp.....TtT
Old May 3, 2011 | 01:23 PM
MassScene's Avatar
BuMp....TtT
Old May 3, 2011 | 06:16 PM
MassScene's Avatar
BuMp....TtT
Old May 4, 2011 | 04:18 PM
MassScene's Avatar
BuMp.....TtT
Old May 5, 2011 | 03:13 AM
MassScene's Avatar
BuMp....TtT
Old May 7, 2011 | 04:47 AM
MassScene's Avatar
BuMp....TtT
Old May 7, 2011 | 06:20 AM
Rsdc5's Avatar
part block? such as oil pump, water pump, timing chain & tensioner?
Old May 8, 2011 | 06:01 AM
MassScene's Avatar
No Part Out......Complete Block ONLY....BuMp....TtT
Old May 9, 2011 | 02:39 AM
MassScene's Avatar
BuMp.....
MassScene
Northeast (Sales)
10
May 16, 2011 04:08 PM
dirtyharryhatch
Mar 28, 2008 05:33 PM
J2turbo21
Mar 16, 2003 08:21 PM
J2turbo21
Mar 14, 2003 09:01 PM
