Need help! fuel issue.. fuel comin from exhaust
Old Apr 30, 2011 | 01:14 PM
DAintegraGSR's Avatar
Default Need help! fuel issue.. fuel comin from exhaust
ok so long story short, had a mean missfire a few days ago. cyl 1 plug was soaked in gas, gas was leaking through the header gasket etc.
got new plugs, wires, cap, rotor, injector, fuel filter even a fpr cause i had a spare..
soon as it started i could hear, feel the difference. Every thing was good untill an hr ago... benn driving all day.
Cyl 1 just misses, i can pull the wire not a single diffrence in the engine.. i swapped plugs a couple times.. cyl 1 plug ends up soaked in gas ??
I even swapped injectors.. Taking cyl 1 moved it to cyl 4.. let it run a min, pull cyl 1 plug.. gas? pull 4 no gas.. so it cant be the injector.
The only thing not replaced is the "thing" lol on the fuel rail that has the line from the fuelfilter.. This is located just above cyl 1 on the fuel rail.. any idea ?
thanks in advance
Old May 1, 2011 | 08:02 AM
Default Re: Need help! fuel issue.. fuel comin from exhaust
anybody..
Old May 1, 2011 | 09:37 AM
mark@silbernage's Avatar
The fuel in #1 is a pretty serious thing; if there's so much excess fuel it's coming out the exhaust there is also a good chance it's washing the cylinder walls and contaminating the oil. It has the potential to wash the cylinder walls and damage them, pistons, rings, etc.
So don't run it that way.
Sounds like it ran until the new plug fouled and then went back to missing.
The real issue is why, right?
If the problem didn't move with the injector, it seems more likely confined mechanically to cylinder #1.. I suppose there's an outside chance the injector driver is heating up and failing (ECU), electronics can fail that way, but it'd be pretty far down my list.
Have you checked valve adjustment and compression?
Tell us a) what if anything you've changed lately b) about the MMY of the car c) anything significant about the engine (from stock) d) how many miles on the engine?
Good luck
Old May 1, 2011 | 09:46 AM
el crapitan's Avatar
i'd run a dry, then wet compression test. compare the numbers.
Old May 1, 2011 | 10:39 AM
MD426's Avatar
Maybe it's not firing hot enough and not burning the gas. Check the cap and rotor, also try a different plug wire to see if that changes anything.
Old May 1, 2011 | 05:56 PM
Thanks fellas.. i did do a compression check every think checked out fine, havn't done it wet.
its a stock b16 with ctr cams.. obd 0 nothing recently changed like dump *** i did throw some octane booster in forgot to gas.. stalled just above e then this started..
did the full tune up cap rotor plug the injector etc..
ran great for a bout 2 whole days.. parked really quick about 10 mins started back up.. misfire.. cyl 1 plug soaked in gas.. fuel leaking from exhaust..
so much i have a huge puddle from the muffler after a ver 2 k rev's
Old May 1, 2011 | 07:43 PM
as stated, try swapping the wires around.
if that isn't it, check to see that the injector is pulsing. you can do this by using a 194 bulb from a marker light. bend the tangs on the bulb so they're sticking out. then unplug the injector and plug the bulb into the connector. crank it and see if it flashes
Old May 1, 2011 | 09:12 PM
rlacsamana1989's Avatar
as he stated in his op he changed the various things you guys have suggested plus some.
Old May 1, 2011 | 09:24 PM
oh ye. didn't see that he'd changed wires.
i'd try checking injector pulse then
Novz
Jan 7, 2011 11:47 AM
-Bionic-
Oct 26, 2005 09:16 PM
JBBNJ609
May 14, 2004 11:53 AM
azzenco
Jan 14, 2003 05:15 PM
