B16 into EG
Old Apr 30, 2011 | 10:42 AM
onimudvayne's Avatar
Default B16 into EG
I have A 95 civic EG hatch that has had a d15b vtec swapped into it. Well i believe the head gasket just blew in it and i'm looking to swap a B16a in it that has been sitting in my garage for some time.
Well ive searched the site and have found a lot of good info on doing this swap but was wondering about the mounts and shift linkage. i have the driver and passenger side mounts from a delsol and they match the set that is on the d15b. i was wondering if the mounts and shift linkage from the d15b would work on the b16a swap. the second issue im running into is that the driverside engine bracket (the one in the area of the timing chain) has been replaced on the b16a because it was in a crx. will the d15b one work? if not WTB one because i cant find one. any help would be appreciated
Old Apr 30, 2011 | 10:46 AM
Jay_Mills's Avatar
Default Re: B16 into EG
well i am doin a b18b1 swap into my eg coupe... soo from what i know the shift linkage from the d15 wouldnt work because i had to change mine to integra linkage.. idk about the brackets i went the safe way and bought brackets and mounts from an integra..
Old Apr 30, 2011 | 10:53 AM
thanks for the quick reply. i looked up the part numbers for the mounts from a Del sol with a b16 and they match the current mounts i have in my hatch at the moment but yeah i may have to by the teg mounts . anyone else?
Old Apr 30, 2011 | 11:35 AM
Jay_Mills's Avatar
np bro its always good to have a little help..
Old Apr 30, 2011 | 12:32 PM
egblack94's Avatar
hey dude whats going on im doing a b18c gsr swap in my eg coupe (dx) can you let me know what axles ur using, t bracket etc.. i would really appricate it thank you
Old Apr 30, 2011 | 03:07 PM
chikichimo's Avatar
Correct me if I am wrong, but from what I understand you will need integra: mounts, linkage, axles, etc. Hope this helps.
Old Apr 30, 2011 | 11:39 PM
eghatch9295's Avatar
Stancetard Hate Monger
b series axles and linkage. dc integra t bracket. timing side mount is the same, i always use dc integra trans mount. not sure what ecu youre running... p28 is ok temporary, but usdm p30 is great... and someone is selling one on here cheap.
Old May 2, 2011 | 12:59 PM
k , i have the axles and p30 guessing i just need to find some dc mounts and that t bracket... having so much trouble finding that for a decent price. thanks for the info
kornerk12
Classic Hondas
Jun 9, 2009 04:32 AM
coffee_junkee
Dec 11, 2008 12:15 PM
shaughn
Apr 3, 2006 01:03 PM
vntperformance
Sep 4, 2003 09:28 AM
